Axial SCX10 owners, what batt size?
xxgg
YYZ
Hi,
Just wondering what size (mah) batteries do you use with your SCX10?
and do you have the battery placed in the front or the back?
Thank you.
Newbie Question.
i run a 4s 1850mah lipo, turned side ways just behind the front shock towers, 18.5t ballistic crawler motor and get around 45 min run time, but i hammer down 80% of the time
I use zippy flightmax packs from my mini revo up front. I either use a 2s 2200, a 1600 3s, or the 2 2200s together for 4s with an lrp 21.5 on a mamba max pro.
I run a 2s 5000mAh 35c up front. Motor is a Trinity 27t, Novak Rooster Crawler esc, with stock gearing. Great runtimes and very good wheelspeed...
I run 3s 5000mah Blue Lipo behind the front shock towers, Tekin FXR, Axial 27t with stock gearing. I haven't checked run times, but it's a looong time, and I hammer on it."thumbsup"
I guess Honcho has to put it's battery up front with stock body.
I just wanted to know what other drivers did because with front mount battery I thought I was putting too much weight on front.
I guess my 2S 5000mah (batt from Slash) is too heavy for front as it tips over to side easier compare to rear mount.
7.2v 4x2 pack on a special carbon fiber plate mounted on front upper control arm links low and Velcro d for quick change fast charge"thumbsup"
might try lipo but ill probably just try that on new rig
i am running a 3s 2200mah hyperion next to my frame mounted servo up front. i have really good run times and a 45t motor. it lasts a day of comping that includes 4 corses and an hour trail run and still have enuff to bash.
I normally run a 3s 2200mah batt up up front but have also ran a 2s 5000mah out front with pretty much the same performance. But the fact that I run 3oz weight in each front tire probavly makes a difference.
I use a 12000mah max amps 2s with a velenion brushless and 24t pinion and i can run for hours with this thing and it gives me the added traction i need for sled pulling and keeps the ass down while im in the mud not to mention crazy wheels speed
I run 2200 mah 2s lipo long run times, i do however run a separate 450 mah 2s lipo for my winch though."thumbsup"
i have just bought turnigy 2s 1800mah 30c and 2s 3000mah 30c for my new honcho , i also have 2 2s 5200mah 30c hard case for the sct. using the accucell 6 charger .
