8threads
So recently i upgrade my Wraith to a MMP and ROC 412 3100kv motor (on 2S battery). I quickly realized how "unstable" the Wraith really is, so i went ahead and installed Axial's "sway bar" kit, front and back.
It wasn't long before i noticed how much less articulation my Wraith has now, like borderline remove the sway bar kit. I DID however LOVE how straight the Wraith shoots at full throttle WITH the sway bar kit installed. When i hammer on it, it back flips with NO hesitation.
But i wanted best of both worlds, great articulation when crawling and great stability when bashing/high speeds. The problem with trying to achieve this is that the sway bars are secured via nut to the shock mount and i'd have to remove or re-install them depending on the type of wheeling i was doing that day.
I got to thinking why there was no "quick disconnect" option with these things, and came up with what i thought was a great idea; adding ball links to the end of the sway bars to pop on and off as needed. Here are a couple pics I took of my mod:
Front:
Ball Links:
This mod isn't really tested and perfected, and i know overtime the plastic couplings will weaken, but it's a start for me. Also - it is sort of difficult to pop the ball links on and off, but i don't expect to do it often. I'll continue to look for alternate material that could suite this mod better. One potential problem i will still have is where to secure the sway bar to when I have them disconnected. I'm thinking bungee cord to frame for now.
Please share any thoughts or opinions!
Front:
Ball Links:
