Axial vanguard AE 3 brushless esc wont enter calibration
Dosman
Lavington
Hello from oz
Just finished a CR01 land cruiser 40 build and decked it out with a savox high end servo absima cr6p 6ch trans and receiv and a axial ae 3 esc and axial 2900 kv brushless motor
Truck looks great all the electrics work spot on
Except when i try to program the esc
Ok so this isnt my first rc more like my 20th
But never used this esc before
So no stranger to esc setups
Hold trigger turn on car lots and lots of beeps 3 sets of chimes flashing red light
Still holding trigger green and yellow both flashing????
If i dont let go it stays like this
Release trigger solid yellow car good to go
Any ideas??
Welcome to RCC.
Do you have the Axial manual for the AE-3 ESC? If not you can go here to see/download -
http://docs.axialracing.com/instruc...-i001_-_Manually_Programming_the_AE-3_ESC.pdf
To enter the programming mode -
Hold full throttle on the transmitter and turn the ESC switch ON. After a few seconds you will get the four rings in a row signaling full throttle calibration. Keep on holding full throttle. After a few more seconds, you will hear another four rings in a row. After the second group of four rings, relax the throttle to neutral. If you have successfully entered programming mode, the ESC will beep twice, pause, and repeat the two beeps.
To continue from there you will need the manual to know what settings you are changing and how to change them.
