BobTeagle
i saw this in stock at Tower so I ordered it.
ax31251 axial XL front swaybar
Im thinking it will also help with torque twist as well! A front sway bar seems as though it would add resistance that will keep the right front tire front coming up
It would for sure. Right front tire 6" in the air without the rear sway bar and 2-3" with it. The better forward momentum gained by having the sway bar and it not allowing the Left side of the chassis to twist is the reason the Right wheel doesn't come up as much. Throw in a Front sway bar that will keep the arms in check will nearly eliminate it all together IMO. That will aid in traction rolls etc. l also guess suspension tuning will need to be done as it will be a different animal after the Front sway bar install.
I am trying to figure out a way to offset my rear upper links as well, like I used to do with my old AX10 comp crawler "thumbsup"
The Hot Racing design mounts to both the front of the bulkhead and the lower hing points on the front bumper. Mine tore out of the bulkhead as well, but the bumper hing attachment has held.
Ok don't laugh. I decided to go ahead and try the swaybar. I did not bother with the grub screws in the bulkhead. I used a part from the Axial light bar kit. It's a lttle redneck rigged but it works so far to keep the bar in the bulkhead slot without breakage.
