Rock Worx
Back playing with the WK
To re-cap work done so far,
i brought a wheelie king 2wd £149.99 which i throught was quite a bargin, i also brought the 4x4 conversion kit £80.00 and a Matrix Pro Lathe Motor 65T single £29.99. so you can gess what i'm up to at the mo...
4 wheel drive with locked diff's (Araldite)
i brought all my gear for http://www.heathsrcmodels.co.uk/ they don't have the 4x4 conversion kit on their web site but if you email them paul@heathsrcmodels.co.uk and ask for the w/k 4x4 conversion kit, or these are all the part no. that came in the kit and u could source the else where,
All are HPI racing parts,
A431 - Diff case £3.49
A855 - Diff Final gear set (P1x38T/P1x13T) £4.99
86014 - Gear diff bevel gears(13T+10T) £5.99
85258 - Uni Centre Drive set mittlkardan set (montiert/Wheely king) £9.99
86813 - Drive shaft 6x82mm (2Pcs) £9.99
86810 - Gear Shaft 5x6x29mm £5.99
B030 - Ball Bearing 10x15x4mm (2pcs) £15.99
B022 - Ball Bearing 5x11x4mm (2pcs) £14.99
B022 - Ball Bearing " " " " " £14.99
hope this helps
I had some Laser Profileing done, for the Chassis and the servo's and also the Motor Plate, Because i used the battery end as the front and a smaller gear on the motor the battery housing wouldn't let me drop the motor down enough so i got the extra motor plate made and spun the motor around and used some machined spacers.
I then Brought (off the BAY)
2x Traxxas #4951 Half shafts, long (heavy-Duty) with metal u-joints
2x Traxxas #5138 turnbuckles 106mm Front tie rods
2x Traxxas #5139 turnbuckles 116mm
and added rear wheel steering
i just need a deasent controller too be able to use the rear wheel steering ??
i did find this but its in the states http://www.clodmodracing.com/products/index.php?product=Dig Steer
http://www.youtube.com/watch?v=6-aUkNDMgDA
hope this helps
