batteries help
racerxrc
middleton
just got a bully 2 what batteries are you guys running randomly looking on amazon by size to fit on tray looks like 3s 600 mah is that enough
what brand and size are you running?
I run the tattu 3s 850mah. They fit the tray without extra room. The 3s 1300mah work but push the size a little. I personally am going to try to lift and angle the tray to help some
I got zees 1500.
After numerous charges they are holding up just fine. My driving style is benign for batteries because I only do slow rock/obstacle crawling, applying just a bit of throttle, pausing to check line, throttling again. My servos (front and rear steer) probably consume most of my battery power. I try, try as much as possible, not to spin tires, which also prolongs battery, and tire use.
1500 is a big case, and as my driving improves and smoothens, driving time on a charge can go over two hours, so, I would advise a smaller battery: 800, 600 or even 400.
