Boopernator
So I have decided to build a crawler on my own, after having so much fun with my Berg tracer V3. I have been reading as much as I can here and also sent Erik a PM. The Berg Bible has been the most help along with all the other build threads here. This is the list of what I have and what I think I should purchase.
What I have already from my Tracer that I'm going to start with and upgrade as I learn more.
Electronics: Airtronics MT4 radio and receiver, Hitec HS 7954 servo, two Tekin FRX esc's with two Tekin 45's motors and Castle BEC.
Wheels and Tires: nothing special PL Chisels and PL beadlocks, and RC4WD comp tires on CI six shooter wheels. Meh :roll:
What I have bought so far is RCBro's Executioner V2 chassis, 2nd and 3rd Berg gears, and egressor shocks.
I want to order the rest from Dlux,
2.2 Superlite's 00162 (the kit style where everything is all together)
Knuckle's 00111 (AX10 stub shaft, Wraith/XR C-hub?, this is where I get confused)
Then Links, Erik let me know he does not have links for this chassis but can make them if I give him measurements. I don't know the measurements I need. I sent a message to Erik asking if his pre-made sets for other chassis would work, the SuDu Pro looks like it might work.
I might be better to order Axles A-la carte, but I would need some sort of grocery list or cheat sheet.
Then gears, What is the gear that connects to the locker? And what about the shafts that the gears connect to?
Thanks for any help that can be provided, I saw the Kit 101 and thought it might be the way to go. But I really like the looks and adjust ability of the Executioner V2.
