When running brushless in a 1/10 crawler with a 2 speed trans what would be the a good KV motor to get?
I'm now to this so still figuring things out.
Am I right in assuming a low KV motor like 2200KV give you better crawling power and something like a 3700KV giver you faster speeds?
Will the 2200kv stay cooler when crawling?
With a 2 speed trans can you get higher top speeds when wanted?
Something in the 2200 to 3300 is a good start for a 2 speed. Allows you to use a smaller pinion if you go with the higher kv . The whole intent of the 2 speed is to get higher speed when shifting gears. or have a "fast" speed that's your normal and shift down for slower speeds. However, most 2 speed trans out there have a very low 1st speed so people use that and shift up for speed.
No question on a 2 speed you should use a brushless motor. Simply because at the higher gear at high speeds, if you face any load (like hills, mud, snow) it is too much for the brushes on a normal brushed motor to take. Most 4 pole brushless motors don't break too much of a sweat but get warm.
Yes, in general a lower kv brushless is good for crawling vs. a higher kv. However most of this can be handled with trans and axle gearing. For example. I have a Tekin Roc412 in 2300kv and 3100kv. I've put them both in the same rig, but changed the gearing to get the same wheel speed (56/9 for 3100 and 56/12 for 2300). Both crawled equally well, however the 3100 got a lot hotter under extended duration at full speed. I was surprised due to the gearing. This is all on 3S in a pretty heavy 2.2 scaler.
On the other side, I run a 3300kv HH Trailmaster Pro (2 pole, not the 4 pole pullers) geared at 56/12 in a 1.9 scaler. This motor stays perfectly cool and has all the top speed I could use. Plus it crawls buttery smooth. My point is that you can make most motors from say 1800-3500kv crawl really well if you handle gearing well. BTW - these were all run with MMP escs.
Getting back to the OP question. I run combinations of both brushed and brushless motors.
I agree with one poster that all my trail/g6/ttc rigs are brushless. All my scale comp rigs and sporty/mod rigs are brushed.
I used to run brushless in my scale comp rigs as I only had a couple, but as my garage has proliferated, I have the luxury of multiple rigs now.
Brushless worked fine for comps but lacked drag brake like a brushed motor. This is an advantage on a steep decent when you are going face first as the truck will slowly drive right down the hill (even with the MMP set to full drag). I've owned half a dozen brushless motors for crawling and none of them can hold drag brake like a brushed motor. Yes they will do an endo when you let off throttle from high speed, but in a steep crawl, they don't hold. On an up hill when you are trying to maneuver to a gate, if you let off throttle a little it rolls back a little and you have a reverse penalty. The brushed rigs I run in comps now all have HH BRXL so I get the holmes hold function on the drag brake. Plus as long as the tires are holding, the truck doesn't roll back. I run these brushed trucks on 4S lipo to get the wheel speed when I need it. Maintenance is just sending them in for rebuild once a year.
Lastly, there is a benefit to startup on brushed motors, no matter how good of a brushless setup you have. It's those times when trying to enter or get through a gate at a true snails pace, you realize the benefit.
If you have 1 truck and you plan to comp and run G6/TTC/Trail events, go brushless.
If you have the luxury to have more trucks, mix it up.
On the question of $100 motors. No big surprise to me. I run some HH pro motors and Brood motors worth $70-100 new. I just keep rebuilding them. Some of the serious comp guys get special motors from brood or HH that are $250 plus for a brushed motor. These will exceed the speed and torque of a lot of brushless motors...until the brushes wear out :mrgreen:
