BluemonkeyRC SCX10 Steering Axle Upgrade Kit
London, United Kingdom
This is on a GCM chassis, but posting here as it relates to the SCX10 axles I'm using with it. I recently purchased the SCX10 Steering Axle Upgrade Kit from BluemonkeyRD - here's how I installed it -
Got everything installed and wired up tonight, and tried the steering. Works fine, except that the left-hand VP Wraith C-hub works itself right off the axle after 3 or four left/right turns (with wheels in the air).
The right hand hub is fine.
I've tried tightening the nut and bolt on the C-hub as much as I can, no luck. Any ideas what I might do to fix this?
Place the chub's at the angle you want them. Drill and tap a 3mm hole through the top slot and the bottom slot. Insert a 3mm screws and bam........
Yeah that seems to be the best option. My crazed tightening earlier stripped a nut so have that to fix too. A little disappointed - hard lesson to learn (I'm new at this).
Thank you, though.
