Welcome to RCCrawler Forums.
These are the Golden Horizons Beadlocks I've had for a few months now, when purchased they were Anodized orange but after installing a different body the color wouldn't work anymore so I stripped the anode off. Now since thye looked a little plain I knocked out some holes and used a Uni-bit to give a 2 step looking hole.
Also installed some Ultra Soft Venom "Switch backs" I found on Ebay for $3.70 a pair, all four delivered for under $12.00, what a bargin. But after trying to put them on the rims I had seen why. They were a bit to big and would easily pull out (another sexual enuendo) from under the beadlock ring ? So I cut and removed a section and glued the tire back together and they fit nice and tight, a quick test should prove they hold or not but I'm confident since they will.
The Viper motor was very nice but since my rig is pretty heavy I opted for a Tekin SC4x 3000kv 550 motor to bump the power up a bit, it runs a little cooler due the larger rotor and more torque.
For a wraith or any crawler that doesn't weigh as much as mine I'd highly recommend the Viper stuff.
I've ben testing these the last few weeks for RC4WD in my Ridgecrest and I assure you they are supper badd assed !
Ben trying to break them on 3s and Tekin 550 motor and couldn't do it, the are still smooth as butter and show little to no wear after 25 some odd packs.
