Purchased my TF2 kit from Tower Hobbies on Sept 18, along with a Tekin 35t and FX-R ESC.
Right out of the box the front differential was missing the inner pinion shaft bearing. Contacted RC4WD and they sent me replacement. All was good. And then....
I got the kit assembled and everything dialed in perfectly, and took it outside for its maiden run this past Saturday. Within 5 minutes of sidewalk cruising and fine tuning, shifted to 2nd gear, hit the throttle, and the truck slowed to a crawl, eventually coming to a full stop. Motor revved, but truck sat still.
Took it back inside and disassembled it. Found that the 2nd gear in the transmission had literally SNAPPED where it's pressed into the drum. !! This happened on the truck's very first run! Didn't even make it to the TRAIL.
Anyone but me ever experience this? I contacted RC4WD customer service and received a reply from "Tanecia" saying that they'd look into it, and get back to me. That was a week ago. Nothing. I should have a replacement gear by now.
Frustrated, and disappointed in this truck so far. I sold a perfectly good running Tamiya Ford F-350 High Lift to finance this build.
Mike F.
[/IMG]
Mike F.
