I've wanted to tackle a brushless camera gimbal for quite awhile, but not for my quad. I wanted to build one that was meant to be hand held, to help smooth out video as I'm jumping around the rocks.
If you are familiar with sites like Thingiverse or GrabCAD then you may know that there are plenty of options available for download. These are all pretty much based on quadcopter uses. However I wasn't all that interested in using someone else's design and adapting it to my use. I wanted the design project for myself. I have also found that I get annoyed with other people design style, just because it's different than mine (not wrong or bad, just different).
I ordered up a few brushless Gimbal motors (1 larger and 2 smaller) to start working with. The larger motor I ordered is listed to be able to work with anything up to a compact handheld digital camcorder, while the smaller motors are made for GoPro size units. The controller I ordered was a cheap version from Hobbyking.com and only cost about $40.
Next up was the design. I drew the motors, and brought in a GoPro model. I created a sleeve that the GoPro would slide into and then be retained by a rubberband or strap on the end. I positioned everything so I could start connecting the dots basically.
