Okay, so what is the relation between turns and amperage?
OK, so what is the relation between turns and amperage?
It varies. The best thing that you can do is research the particular motors you want to use and see how they run. There is no universal number that goes across the board.
"In general", the lower the turns the higher the amps. More power (lower turns) typically the higher the amps.
Granted, there is a difference between manufacturers and machine wound vs. hand wound.8)
I'm goin with the Traxxas 3s velenion system for my scx10. The Traxxas speed controller is already waterproof, and has different settings. The people who pointed me twards that said that sensored motors only eliminate coging, which the low gearing should do anyways.
Oh! And Dollarhobbyz.com under traxxas slash 4x4 vxl isa good place to get it cheap....er. 8)
I have the BrushlessHobbies and the Crawlermaster motor. As the guys said, you'll never tax the 120a ESC with that motor but I'm going to use it in my Wraith. When we go to the beach I'm stuffing my Castle 1410 (3800kv 4 pole) in the Wraith for some FOFF fun!
Anyway, the speed of delivery and the support from BH has been great. I still don't have mine all the way setup but from what I've seen I like it quite a bit. Also, my Crawler Master motor (same as yours) is brand new and I've never used it so I'm not sure how performance is. With some initial bench testing I'm worried the sensor board in that motor may be bad because it doesn't seem to run any different sensored or unsensored.
I really need to get a sensored motor that is known working and see how that runs.
