brushless motor/esc on ebay. worth it?
not a smart choice imo. you would want to go with a sensored brushless system. this is sensorless. so you will get cogging at low rpm's. which, is where you do your crawling. senorsed is the way to go. besides that, i really dont see much of a point in a brushless system in these guys. kinda overkill..
power man! "thumbsup" im gonna buy wheels and tires.
umm ok. and what wheel and tires you buying? 1.9's? j/k ;-)
i'm running miclaws with 30 grams on each front tire. stock esc with the predator motor has more than enough power. are ya building a rock racer?
nah. was just wondering what options i had. that brushless system is a good deal so jsut wondering. not sure at what wheels yet, but the tires are gonna most likely be the crushers. the only tire i can get ahold of
If brushless is a must you are better off with a micro outrunner. a few have mounted them before and sensorless outrunners wont cog as much and have much more torque.
if you just need torque in an easy bolt in solution get on the list for one of getbents predator motors. direct bolt in,dual ball bearing, lots of torque,a little slower than stock for easy crawlin. best of all it works with stock electronics
another option with less torque but also a bolt in is the atomicBB II if you can find one
