spyderwebbcustoms
I'v got a question for some one that is smarter than me!
my qt. is that if this motor will be strong enough to run in a crawler
specs.included
will be running a sidewinder, if not then mamba max 3cell lipo 20c burst at least the smallest batt that I want to run
will be running axial axles with summit two speed stock gearing pic's included to have a better idea of what I'm going to run it in.
the price is right for the motor but I don't want to throw my money away,
so comments are welcome, fedback a plus. thanks to all that reply
MODEL : TR42-40A
Max Efficiency : 30A
Max Load : 35A
Kv : 1050
Power: 550W+
Weight: 125gr
Pull : 800-1200gr
Porp Size: 10x6 or 9x5
Voltage 5-15v
No Load Curr: 3A
Size: 42x40mm 5mm shaft
Power equivalent : .30 to .35 glow engine
Kv (rpm/v)1050Weight (g)125Max Current (A)0Resistance (mh)0Max Voltage (V)15Power(W)550Shaft A (mm)5Length B (mm)40Diameter C (mm)42Can Length D (mm)17Total Length E (mm)60
specs.included
MODEL : TR42-40A
Max Load : 35A
Kv : 1050
Power: 550W+
Weight: 125gr
Pull : 800-1200gr
Voltage 5-15v
No Load Curr: 3A
