Hi guys,
how's things? I am a RC fanatic based in Australia and I'been looking at this forum for a while now and getting inspired by so many awesome TH builds.
So I decided to get a kit and build my own and the idea is to build a Twin Hammers for speed. The buggy will have as low a COG as I can get and the front diff will be quite loose.
Originally I was looking at the GCM front end setup with the battery at the front, but then reading that the bell-crank steering kit from Sr.Irie, wasn't really available I ended up looking into the Scorched parts 3D printed components and I must say that from a build point of view I am very happy with them.
I also decided to install the dual rear-shocks so I tried to order the shock mounts from BlueMonkeyRC, but without success. So for the moment the TH has a single set of shocks at the rear. Looking into the BoomRacing shock hoop extenders as an option now. But if anyone has a better idea, please let me know.
I also got the upper rear links and trailing arms from Vanquish (again to replace the BMRC parts that I was really after)
For the electronics I went with the Castle Mamba X and the Castle Slate sensored 3800kV. The servo is a XPert 6601 (a bit less torque than the 7701, but a bit faster).
For the moment I'll use velcro straps for the battery: light and cheap option. Let's see how that holds up on the jumps.
After I am happy with the build and electronics setup I'll then work at making it look a lot more scale. But it needs to run well first.
Hope you like where it is at so far.
