CamoColton
Bought this kit when it was released and finally assembled it last month. I didn't take photographic record of the build process, because it's really nothing special at all and most of the parts were things I had laying around for whatever build came around next; largely purchased during big sales at Amain. I got the green Huf livery that it seems every one else did too. I purchased the red Eibach panels, and applied Freqeskinz "Crazy Ivan" wraps. I went with the HWO grill just because I like the look of it better, and also to disappoint purists that see a Toyota livery with a slotted grill. The red panels were purchased so edges appearing around the vinyl wraps worked with the livery instead of against it.
Build list:
Freqeskinz says these vinyls line up with the panels edge-to-edge. And they do. But I think starting from one edge and working across, especially the hood will be a fool's errand. Soapy water, and a hair dryer or heat gun on its lowest setting will be your friends. I spent more time working on the hood then I did all remaining panels. And I had to come back days later with heat again to get the wrap to stay adhered, and conforming around the raised center section of the hood.
These lights don't fit without a lot of dremel work. I installed the fronts, lenses, and the light's boards, and left the backs off. CA'd the fronts of the lights in place, and then used hot glue to hold the boards in place while I slammed everything back into place on the cage. I am not pleased with my install, as they didn't end up even. Even though I would have loved to have maybe have gotten some free shock parts from Vanquish, the red anodized parts work well with the Ivan livery.
VRD shifter found in my box of misfit parts from previous kits. Spray painted with Rustoleum Painters Touch Aluminum, as was the radiator. Driver helmet painted with Krylon Fusion white (both back of the garage finds).
I'm a real fan of these SSD Contenders. Very similar, if not direct copies to the TRD wheels that could be optioned on the FJ Cruiser (2009? 2010? Trail Teams?), and think the compliment the Ivan livery well. They have SSD's +3mm hubs with rotors to make them fit on an Element axle with the BTA steering where they had previously lived.
Thanks for looking at my nothing special build of an Optic.
Build list:
- Hobbywing Fusion Pro 2300kv (from my own stock)
- Futaba 304SB-E receiver (own stock)
- EcoPower WP832 servo (purchased for this kit)
- SSD 1.9" Contender wheels (from the milk crate of wheels and tires)
- Pro-Line BFG Krawler T/A KX G8's (to replace the Hyrax tires on the SSD wheels)
- MEUS Hyve lights (scamazon)
- S8E anodized shock caps and collars (didn't know about the rebuild kits being offered, these leaked before I even powered up the truck, and the plastic collars are lousy)
