hurricanemitch
I have put all the electronics in my tuber finally but have alot of glitching. I am using the following, all are used.
Novak XRS esc
High tech 645mg
Losi sport 27mhz fm radio
7.2v 650mah ni-cd aa 6 cell
The servo chatters most of thr time, tried another servo, does the same thing. Also when driving the truck will just stop for a few seconds then if I release the trigger then pull it again it goes fine for another 25ft or so.
If I shut off the radio all glitching stops. Also on the back of the radio is a button with 3 colored lights, push the button the lights change order and such but the button on the rec. has no effect on the rec. lights.
I think I have a bad rx or tx or both. What do you think:-(
Novak XRS esc
High tech 645mg
