maverick67
There doesn't seem to be much discussion about caster angles on the scx10.2. The manual states 10 degrees positive caster for the initial setup which is my setting at the moment. But I'm having issues with the tires rubbing on the shocks a little after laying the shocks down a bit as well as installing slightly larger tires. Would it be ok to increase my caster one or two notches? And is it true that increasing caster will decrease my turning ability? I'm interested to know what caster angle you guys are running.
