Castle link stupid question
sullysracin
Etowah
Ok stupid question here but I am finally ready to hook up to the castle program but where do I plug the connector up on the truck? Running a sidewinder
No, unplug your battery pack or at least make sure you have the esc switched off, then unplug your esc from the RX, plug the usb cable into your laptop, then the castle link into the usb cable, start up the castle link program........should see one green light one red light on the castle link program on your pc screen. Now plug the esc rx lead into the castle links lead making sure you match the wires the right way round. You do not need to turn the ESC on at its switch or even have the battery plugged in to update it."thumbsup"
Download the updates, install them onto the esc and tweak as you see fit.
Crawler drag brake option seems to have issues, as does settingt the drag brake above 100% in custom mode.
