CC01 shocks
minicrawler1
Belgium
Hey guys,
I've replaced the rear suspension of my CC with the Junfac 4-link and i am using the GPM shocks.But i would like it to have a bit more articulation in the rear,i've seen some guys use other shocks,wich ones would be the best replacements?
Thanks
i use CR-01 shocks running 100% droop on a GPM 4Link set up and i get a huge amount of flex for a CC, if you want alot of flex i would recommend these, or any other 90-110mm long shocks
Thanks,i'll try using the super leaky shocks from my CR on my CC!
I may be wrong?But i think some guys use Losi shocks as well?
Do you have a pic of your CC flexing?
Thanks
Yes I do in my thread, it's on the bottom of the second page of CC-01 section, and it's called CC-01 FJ40 Touring Rig, also I don't run very much oil at all in the shocks, only enough so they slide smoothly and this way they don't leak, hope this helps"thumbsup"
I am running a pair of HPI Super shocks on mine and love them. I was running the RC10 gold’s prior but find the HPI ones a lot smoother. I really like the junfac kit too. Good choice! Shock Length is 70mm-103mm.
Here is a couple pictures of my set-up.
