Cheap lcg chassis
TyMcleod
Canada
What's a good but affordable set of lcg chassis rails looking at anything 40 and under for price before shipping costs
The CBE Switchback chassis is probably the best deal for SCX10 chassis. They are not as extreme on the axle clearance/skidplate drop as some other options (still more low CG than the stock chassis) but it is hard to beat for the price (about $35) and versatility. The rails are also way stiffer than a stock chassis, my Switchback has nearly no flex with just a skidplate and bumper mounts installed.
Never know the stock scx10 ii chassis will be flex. Did not they are made by steel or iron? And they still flex under load? Would like to know more :)
If you have a SCX10 or SCXII, grab the chassis by the bumpers and give it a twist. There is a ton of torsional flex, most aftermarket frame rails eliminate this by being made from thicker material. The CBE rails are made from 12 gauge steel (~ 2.75 mm thick) versus the stock Axial rails which are about half that. Axial did use a c-channel design which helps some but not as much as the heavier duty material.
