hpiguy
I used a 4" grinder with a cut-off wheel.
Clamp the guard of the grinder to a flat table so you don't have to hold it steady (my grinder stays turned on without holding the button).
This allows you to lay the wheel on the same table and "push" it into the grinder wheel to make the cut.
Then you can "turn" the wheels with both hands and the cut will be perfectly flat.
I used some various pieces of flat metal to raise or lower the wheel until it was cutting exactly where I wanted.
I don't remember how much I cut out, but my wheels ended up being around 7/8" wide measured at the beadlock face (plastic, not the rings).
Cut the beadlock free from one side, run a screw all the way in through the beadlock ring and plastic wheel to see how much sticks out of the backside. This will determine how much you can remove without that screw hitting the screw coming from the other side.
I had a 2mm tap, so I tapped the plastic holes after the cutting was done just to make it easier to run the screws in, but that may not be necessary.
I used 3 bolts to make sure the wheels were lined up correctly, and glued the edges, tightened those 3 bolts, and then ran a bead of glue around the joint for extra piece of mind.
Let them dry, pull the screws, drill new vent holes (old holes got cut away), and install tires....
Thanks for taking the time to write all that up. For now, I gotta get through Christmas buying for others. I don't own a grinder or drill press (and don't like borrowing tools), which would both be needed for the mod it seems. Might just be cheaper to buy a set of SLW compatible wheels in the long run in my case. Someday, I'll own a nice shop with a decent house. :mrgreen:
Looks great so far. What is the name of the chassis
It's a Bender SWX chassis, circa 2008 I believe.
Well, I spent the rainy crappy weekend pretty much finishing this rig up, for now. With the custom front axle setup, I'll need to pick up some wheels that let me run adjustable offset hubs, but that will have to wait until after Christmas. For now, the pro lines up front and rocksters in back get me closer than it was, still just over an inch off though; I'm at 11" front TW and almost 10" rear. I'll also add some UD / OD gears in the future as well.
I'd also like to give a big thanks, to everyone that's helped me out on this build. And its not done yet, just paused until Christmas is over with and the bank account recovers. :mrgreen:
Finished up the steering rack and electronics, running another BIA RX, I love these things. A 3s 460mah pack fits just right (it can lay flat if I want also), just need to solder up an adapter from JST to Deans.
This is how much steering I ended up with, with nothing binding, and nothing rubbing anywhere
And of course, some poser shots complete with new stickers :mrgreen:
