WRXronald
Got the MT Baja Pro X's in 2.9 (Prolines) on G8 compound -- thinking this will be the setup. Just not that into the scale looking Tusks.
So the 2.9 Pro X's on the Chevy K10. And then gonna do the 40 series Pro X's on the Unimog ----- almost done setting that rig up --- silver cab, flatbed, and completely waterproofed out the gates, gears, electronics, everything torn down and dealt with in advance. Just have the Rx left to install and waterproof.
I'd say grippiness/stickiness of each tire felt similar new -- maybe the X2S3 RC4WD was a little softer overall but the G8's were surprisingly sticky even compared to the JConcept GREEN Tusks to the hand, ya don't notice a big difference and even after cutting the JConcepts foam down, the Proline 2.9 foam is MUCH SOFTER and I didn't cut a V Pattern into it all I did was cut 16 "slits" and leave 100% of the foam in tact. Way softer.
The RC4WD's are super puffy and wide looking which I think looks great on the Unimog -- that's a heavily inflated inner tube tire plus 1/4 thick RC4WD foam on either side of the inner tube taking up space and keeping the sidewall when the inner tube is aired-down.
I should have done some pics of each tire side-by-side --- they are essentially identical in diameter but the 40 series is about 1/8inch or so wider overall at the widest point.
A few pics of each rig now...
Also - when I tore open the portals - I notice the small portal gear also uses a 2mm drive pin
So its been pretty pointless to go machinging out the transmission 2mm drive pin up to 2.5mm when there are still four other 2mm pins remaining. (UGH!!! What is wrong with CrossRC --- I have 1/18 scale rigs using 2mm dowel pins that weigh less than 2lbs all up!???)
Anyways -- going to try out 52100 Bearing steel hardened dowel pins --- in 2mm --- and see if they hold up better than whatever CrossRC uses stock. I got a full set so will do the portal pins in both rigs and also do the transmission pin in the new silver Unimog and then hit 'em hard and see if they hold up.
Hopeful!! But also buying more 2.5mm End Mill bits so I can do all the machining on the lathe if need be after all. That's 10 gears to machine in total on both trucks so assume quite a few end mill failures. If I blew thru 1 end mill per 2 gears that would still cost me over $70 in wasted end mills just to get the job done. fug.
