Choose Your Own Color Rock Lights
heyok
Vancouver, BC
This is a set of Rock lights that let you adjust their color.
This is a set of Rock lights that let you adjust their color. Connect them to a linear or two/three-position channel and you can set them from Off to White. In between, the color changes.
That's confusing, isn't it?
Let's pretend it is on a linear channel with a knob. At one end of the knob's rotation, the rock lights are off. Turn the knob a little and the rock lights come on with a color (let's say Red). Keep rotating the knob and the color changes... yellow, orange green, blue, purple. Just dial up the color you like. Keep turning and the rock lights light up white.
If you were running this from a two-position channel, depending on where you set your channel's end-points sets the color you see. Start it at black with -100 on your end-point (this varies with transmitter manufacturer) and set the other end point to the color you like or turn it up all the way for white!
Watch it here:
https://youtu.be/ID-SmdZNz90
Available with 2, 3, or 4 LEDs per section (there are four sections - one for each corner or wheel well of your rig). If you prefer a different amount, contact me and I will make something custom for you.
Part No:
CRL2 $35
CRL3 $43
CRL4 $47
