__________________________________________________ ______________
Scale Class: All rigs in the Scale class will start off with 0 points and points will be deducted during the competitions. The object is complete the course without incurring points. Point deductions are listed below. Speed is rewarded.
Reverse + 1 point
Rollover + 5 points
Gate + 5 points
Touch + 5 points
Time: - 5 points (awarded if course completed in time allowance: An additional -5 points will be awarded to the fastest time)
DNF + 40 points + 5 points per gate not completed
*Rescue - 5 points
Reverse: Using the throttle to reverse course. Non powered roll backs are allowed. During gated courses each driver is allowed 1 reverse per gate without penalty.
Rollover: Points are assessed when a vehicle rolls over and does not right itself or can not be righted without touching. Winching is allowed without incurring a penalty. Once righted the vehicle must be driven back into position. All gates not already cleared are still live while on a gated course.
Gate: Failure to pass all 4 wheels through a gate or touching a gate with any part of the vehicle. Gate must be cleared in its intended direction. Winching through a gate is allowed. Once a gate is cleared that gate is dead.
Touch: Any contact made to the vehicle by any person during a run. If the touch is resulting in the vehicle being placed back on course the vehicle may not be placed any further forward than the most recent point of progress.
Winch: Winches may be used at any time along the course without penalty unless any part of the winch touches a gate. If that occurs a gate penalty will be assessed.
Time: A 5:00 minute (or 1 minute per gate) time limit can be applied per run, this is not required and will be at the discretion of those judging the courses.
DNF: If a vehicle is unable to complete the course regardless of reason a DNF will be assessed. If a DNF is assessed then they will be scored with +40 points add to their current point total plus 5 points for every gate not completed.
*Rescue: Using another vehicle to free a vehicle on course. The rescue vehicle will only be allowed during runs in which the buddy system is in place. The rescuer will receive the bonus points.
*Buddy System: When the buddy system is in use 2 vehicles will run the course, the leading vehicle is the one being scored during that run. The “buddy” is the follower and will not be scored unless a rescue is requested. After the course has been completed the drivers will reverse order and the “buddy” now becomes the leader. Driving order will be decided by a coin flip. Buddy pairing will also be decided by chance. Method of determination will be decided on site based on number of participants.
Scale appearance points will be deducted from the final score of each event. Appearance points are listed below.
-5 Points (up to a maximum of 20 points)
·Hard body (rigid construction, usually abs or polystyrene: essentially any body that is not lexan)
·Detailed Bed (drop beds, flat beds, tube beds: should be realistic representations)
·Interior detail (must have at least driver & passenger seat, dashboard, & steering wheel)
·Offroad trailer (must be towed during entire event)
-3 Points (up to a maximum of 15 points)
·Roof rack with large scale item (canoe or similar, item must be secured to rack with tie downs; no Velcro will be permitted.)
·Bed item with large scale item (quad, dirt bikes or similar, item must be secured with tie downs; no Velcro will be permitted.)
·Realistic bumpers (point per bumper)
·Functional winch (per winch, front or rear)
·Functional spare tire (should be same size as being run on vehicle; i.e. no 1.9 spare on a 2.2 vehicle)
·Scale engine (i.e. Parma hemi)
-1 Point (up to a maximum of 10 points)
·Functional Lights (per set: Headlights / tail lights / roof / rollbar / crawling)
·Driver / Passenger figure (should be scale in size, in other words a 4 inch G.I. Joe figure in a 1/6 scale truck wouldn’t work. 1 point per person)
·Spare tire (non functional)
·Non Functional Winch (per winch, front or rear)
·Scale accessories (jerry cans, cooler, snatch straps, etc {multiples of a particular item will only score once: for example if you have 2 jerry cans you will only score for 1 jerry can})
Custom Body Bonus: This bonus is awarded for custom build work done to a body, this ranges from stretching, widening, combining, and scratch building. This is added on top of Scale points.
-5 points for any major custom body work (i.e. building a crew cab, grafting lexan and hard bodies*, etc)
-5 points for major tubular work. (i.e. full exocage, full tube chassis that supports and/or conforms to the body)
-10 points for scratch builds (i.e. building a body from the ground up; no OEM basis)
*50% rule applies to lexan/hard combos; in the case of a lexan/hard combo the body will be judged on the basis of whether it is more than 50% lexan or more than 50% hard.
