BJoe
You don't have the option of opting in, only out.
What does that matter if you can turn it off as soon as it's installed.
Chris, can you elaborate on the disabled statement ?
I called comcast and wanted to opt out or have it disabled. I was told they could shut it off so others couldnt receive the hot spot but that also meant I would not have wifi either. I would still have internet, just not wireless. Or, I could buy my own router to have wifi still which comcast would not be able to broadcast the free wifi signal from....
From what I understood, there was no opt out or disabling the comcast router and still retain your wifi signal for your use only.
It is on for you and all other comcast customers or you buy your own router.
And my point (if we're on the same page) is why am I going to get in trouble for using someone's Comcast free public hotspot wi-fi router signal?
I guess I could read the article...
Edit: Alright then. Thanks Dud.
Edit again: Then mix it up with that certain speed for certain customers and that gets kinda interesting.
That would be my issue. Bubba looking at kiddie porn while feeding off my hotspot.....who's getting raided? I am."Big Brother" doesn't worry me so much as "_______ Trash Cousin" dragging me down for something he did.
I am not saying you should or could get in trouble I simply ask if its leagal & where the lines are (I don't know)
A non comcast router works with comcast service, I do not know about the modum part but my guess is that would have to be comcast to work with there services.That would be my issue. Bubba looking at kiddie porn while feeding off my hotspot.....who's getting raided? I am.
Comcast is available in my area, alot of people have tried to do the basic modem with their own router only to be told by comcast it will not work and they must lease one directly.
Again the hotspot can be disabled and is only available on the Arris 862/852 wireless gateway.
The modem worked fine by itself. The router (linksys e1200 owned) worked properly when used behind at&t modem.
:lmao::lmao::lmao::mrgreen:yeah, those silly techs...I tell ya.This is good to know, even the Comcast techs do not seem to know the answer to this.
I'm a Comcast tech...:roll:
Perfect, thanks for the straight up and accurate info. Now I need to figure out what box I have.
