Szczerba
The Deuce's Wild Foam Line will carry several different design and shaped single stage closed cell foams.
Deuce's Wild Foams
The purpose for the new design:
- improve handling and tracking at speed; essentially filling a tire with more air pressure in the 1:1 world
- 100% water proof
- tunable; the end user can trim the foam ribbing to increase forward bite
- a foam designed for 7-8 pound and heavier scalers
-C.I. vents all tire combos because the closed cell foam is water proof and does not breathe. Without air movement, the tires and foams do not conform as designed. Depending on the height of the tire, it will have either 3 or 4 holes. The size of the breather hole is 2mm.
These are already offered for 1.9 wheels and tires and now they are offered for 2.2 wheels and tires.
Standard and Tall versions for 2.2 Wheels/Tires
Standard
Scale & Competition Crawler Tires.
This foam fits the Axial BFG Crawler; Axial Ripsaw; HB Rover; HB Sedona; Panther Leopard; Panther Cougar, & similar height & width tires.
These foams were designed for use in the RECON G6 trails & RECON EXO Terra racing.
Tall
This foam fits the Pitbull Rock Beast 2; RC4WD MT 2.2 Baja Claw TTC; RC4WD 2.2 IROK, RC4WD 2.2 TSL Bogger, & similar height & width tires.
Got some Duece's Wild single stage foams from Eddie at Crawler Innovations. I think they will be perfect for this 15lbs rig. http://www.rccrawler.com/forum/axial-wraith/462589-szczerbas-2-2-cxt-6.html
I was running 5.25" Crawler Innovations Double Deuce Foams with firm outers.
I got the 2.2 talls and the 2.2 standard. Mounting up the standards for these swampers.
Old setup on top new standard setup on bottom. New setup squares the tire up good and gives it full support.
Old setup on top new setup on bottom. New setup holds the weight alot better with not tire squat. Tough to see in the picture but the old setup had a good amount of tire squat.
Deuce's Wild Foams
- 100% water proof
Standard
Tall
