Crazykev
I still have more that I would like to do to the rig, but wanted to share what I've done so far. I have built quite a few R/C vehicles and must say this one has been my favorite. My last one was a Twin Hammers and flat out hated it and sold it within' months of owning it for a big loss too. It did look cool, but was too small, narrow and easy to break. The Yeti looks almost as good and is a much better truck for bashing. Another thing I like about the Yeti is that I always mod my trucks and is part of what I love about this hobby. Well with the Yeti I feel like each upgrade just makes the truck that much better and not just for looks. I have this geared to do 42-43mph and it is quick! I don't plan on pushing it quicker until I upgrade to the Holmes Puller pro XL motor which is what I plan on doing soon. The current motor doesn't even get close to overheating, so I'm hoping the Puller Pro will give me another 5mph and run at the same temps.
CC BEC mounted in the fuel cell powering the Savox SV-1270TG High Voltage Monster Torque Titanium Gear Digital Servo @ 8V pushing around 500 oz. and .10 speed
Running the stock motor with a 19t pinion and 56t Gen3 spur currently
Transmission gears are HR reversed with the 28t on top. HR tranfercase gears and full Acer ceramic bearings.
Modified Vanquish front shock mount with Icon shocks, Vanquish links, hubs, knuckles Ti-Ni pins and VVD V1-HD axles. I modified the Vanquish shock mount to give me the most suspension travel that I could possibly get with the truck. As it sits, you would have to grind the hubs or suspension arms to get anymore droop and it bottoms out the shocks about 3-4mm before bottoming out the chassis and will after compressing the tires that little bit. I have fully maxed out the front travel.
Rear suspension setup with custom Ti subframe struts
Hub retainer rings I made for the rear wheels. If I rip a wheel off the hub in the front, then I will do the same, but so far have only had that problem in the rear because the servo saver allows it to flex.
UCFab swaybar with Associated blue Ti links. KBess limiting straps
More to come as I keep building
Forgot one of my favorite mods. Open rear diff with GCM case, 2,000,000wt fluid, HD 38/13 gears and Boca ceramic 5x14x5 oversized bearing in the Vanquish V2 axle and the rest of the bearings are Acer ceramic along with the two additional ones in the Axial Full Width Lockouts. I really hated the handling of this truck with the locker, but I never do any sort of crawling and have the truck geared to do 42mph as it sits right now.
It usually isn't this clean, but I had a few days to wait for the new bottom shaft to show up and cleaned it up after I tore it down. Sheared the shaft right where the pin goes through. The Hot Racing gears survived perfectly! I know some people dog their products, but so far I have zero complaints.
Made a Carbon Fiber 1/8" thick skid plate for the front that also overlaps the T-Bone Racing skidplate so it stops snagging everything ya run over. You can also see the 5mm Hot Racing hub spacers I'm running front and rear and the STRC hinge pin bulkhead. I'm running 70mm blue springs with 45wt fluid on the front shocks.
Painted the skull helmets and you can see the antenna that runs up through also.
