Cutting Fenders On A 1:1
twisted
ive been thinking of cutting the fenders on my 96 bronco xlt and putting on some flexi fenders.ive asked on fte board but haven gotten any answers so i thought i would ask here as i know alot of you guys wheel the real thing too. has anyone done it and have pics ? does it look hack ?
thanks
i cut the fenders on my suburban with a die grinder and left it alone, i dont like fender flares though. if thats what you mean by flexy fenders... ill get pics up soon. as soon as i find them
I've done a few. I'll give you my experiences and you can go from there. I've used a sawzall, and it's a little too uncontrolable. I've used cutoff wheels, which seemed to work better but still not a nice cut. Tried my portaband with similar results as the sawzall, just more awkward to use. I think the best method would be air shears. Cut and leave some extra meat. Then go back with a hammer and dolley(?) and bend a nice flange down. That would be a cleaner edge. Also if you have fender trim, preferably metal, you can bend it to contour to the newly cut fender and cover up a rough cut. The thing that always annoyed me was the 2 different layers.
I always use a zip cut on a grinder. I can cut very accurate radiuses and it requires next to no finish work. If you dont like the sharp edge, you can also weld a piece of round bar to the edge. It also strengthens the fender alot. I would skip the flexy flares.
EtypeR's truck I hope the pic shows up.
On my ranger I used tin snips mad for cutting circles. After cut I rolled the edg under. I don't really like the look of those flex fender things.
Use a body air saw. Basically a scaled down sawzall. That is what they are made for. Look on Ebay in auto body tools.
If you are covering the edges with glass, who gives a rat's a$$ how clean the cuts look? Shears, plasma, grinder, etc will all produce a cut good enough to grind/sand down clean enough for an edge that will never be seen.
I use black door edging from pep boys, 12' roll for like 7.00 makes a perfect clean edge over the cut
HEHE............exactly!! I have done the same myself.:)
Here is my truck that Cole tried linking to... The server that I had it hosted on is down, so I put it on my other site.
I used a jigsaw to cut some of my fenders, and a air grinder with a cut off wheel for the others. The Jigsaw worked the best with very smooth cuts and exellent control. I also used pliers to roll the edges back, for a factory look.
thanks guys for all the replys. i got more here on an rc page then i did a 1:1 page lol..
between my brother in laws shop and some friends all those tool i would be able to use.
ill post a pic where i want to cut mine. rite above or on the line where the stock fenders flare out.this would take care of the rust on one fender.
heres where abouts i want to cut.there will be 33" tires on it.the ones in the pic are 31s.
Virgin Bronc............so clean, so pure!
For the love of all that is sacred and holy...............DON'T CUT IT just to throw on some 33s!!!!!:x
Plasma's nice but if you don't have it you can do a fine job with a sabre saw and a fine tooth blade or you might want to use a die grinder. Smooth any waves with a die grinder and/or flap wheel on a 4" grinder.
Put down masking tape to protect the paint and allow you to draw your cut lines.
Jay
