Cutting tires
Weezul
Memphis
What is everyone using to cut their tires? I played around with an old set a friend had and using a razor blade takes forever.
I use a set of flush cutters (sprue cutters/ flush cut pliers) and/or a thin cutoff wheel on a Dremel depending on what I'm trying to acheive. For shaving sidewalls, I've had the best luck with a flap-disc sanding disc on an angle grinder... but you'd better be cautious when going that route!
