delrin
tweak6
Pittsburgh
what is the best way to go about cutting delrin? I am looking to make steering links for super bully axles. I either want to do a BTA setup or a high clearance setup. but maybe a combo of the two
Any small saw like a coping saw or hacksaw will easily cut delrin. As will a cutoff disk on a Dremel. Keep in mind Delrin is a pretty flexible plastic. Links will bend if not fat enough. It's more common to use aluminum or titanium for links. VP sells a nice selection of generic threaded Ti links...just add rod ends.
yes I saw that VP sales links but the longest link they sale is about 7 inches long and that is just not long enough for super bully axles
Thank you, I saw on his site that he made links for a few chassis I didn't know he did custom links. I just ordered a few parts from him, waiting for them to come in. I got the servo mounts and servo strengtheners.
Re: how to cut delrin
An old model building tool everyone should have is a Zona or Xacto razor saw. They come in different lengths, depths and tooth counts. I've used them to cut balsa, ply, dowel, carbon fiber, plastic, aluminum and brass tube. Since getting into crawlers, have used a razor saw to mod wheels/rims. They waste a minimum of material because of the thin blades.
