I am thinking about using some Desert Lizard shocks set up for droop on my TRX-4 but want to keep the ride height the same. I have Jazrider shock mounts which allow me +- 4mm in mounting height at the top and will be getting the GPM lower shock mounts which allow three different positions so at least another few mm of adjustment available from there. I'm hoping to keep at least the same compression travel as stock.
I have two questions. Other than the obvious lower center of gravity, what is the benefit of the droop setup? Is it only the extra travel?
My second question is what is the ratio of droop spring to normal spring in the Desert Lizards, i.e. would I need 110mm or 120mm shocks to get close to the original ride height?
If this is just a dumb idea please explain why.
