I'm not a chemist or whatever so take this with a grain of salt. It works, though.
Supplies
https://www.amazon.com/gp/product/B01BBME8K8/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B081JQV816/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B001QV3DCO/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B07CT1NR6H/ref=ppx_yo_dt_b_asin_title_o04_s01?ie=UTF8&psc=1
IN THE COLOR OF YOUR CHOICE!
https://www.amazon.com/gp/product/B07456SPMF/ref=ppx_yo_dt_b_asin_title_o04_s02?ie=UTF8&psc=1
Battery acid
Plastic/Glass tubs
Aluminum or titanium wire
Distilled water
Degreaser
The process
First thing is you gotta find whatever you want to anodize. I'm using some scrap links for this tutorial. You're only limited by the size of your containers.
Degrease your part and polish it if you want to. Keep it surgically clean and don't touch it with your bare hands. Use distilled water only.
Next, mix up distilled water with a dash of that lye in there. Hang your part in there, let it stew for 5 minutes or so. It'll turn grey.
Dunk it in some distilled water.
Next, hang your part in your 30% battery acid/distilled water. Clip the negative part to the lead sheet, and the positive part to your part. Turn on your power supply. I leave mine at 16 volts. Let it stew for 20 minutes-ish. Turn on your hot plate, add distilled water, and put some dye in it, make it hot. Bubbles will form on your part. Thats fine and what you want.
After that, toss your part in your dye bath. Leave it in there until you get the color you want.
Take your part out, wipe it off in the water. Done.
Its way easier than the internet makes it seem. Any questions? Don't overthink it.
Supplies
Battery acid
Plastic/Glass tubs
Distilled water
Degreaser
The process
