Hey there, currently scratchbuilding my first "sporty" (for cheap, just to see if i'm into it). The build went surprisingly well for a basically complete Aliexpress build so far, there's just one issue.
The suggested carrier bearing prevents the suspension from fully compressing (upper links hit the rod holding the carrier bearing), so i "designed" and printed myself an arched carrier bearing support. Works fine. But it now turns out that the rear driveshaft angle is a bit too steep to run smooth, so i rotated the rear axle forward a bit to get a reasonable angle there, looks like this.
Is it fine to run that angle on the rear? What's the potential downside? If i don't do this, i have to run a single driveshaft to the gearbox, quite severely limiting ground clearance.
Bit above my pay grade, i know that positive caster on the front axle is okay, i got no clue about the rear.
Thanks in advance.
Thanks in advance.
