Ramination
Hey guys,
I had a brake line failure (scary - luckily still in driveway) on my old truck and am in the process of re-doing the whole system. My issue is that I am struggling to get a single good double flare. A couple weeks ago I did the rent-a-tool from AA, :shock: it was in really bad shape, and a cheap tool. I ordered a Ridgid 345 and that is what I am using now, but still struggling.
I think my problem is 100% because the 3/16" line is slipping in the tool, but let me tell you my process, maybe someone can point out where I am going wrong.
I have tried using the little tube cutting tool, and using a dremel to cut the line. I read that the cutting tool hardens the line and makes the bubble part of the flare difficult. I have had similar results with both methods.
Anyways, once I cut the line I put it in the jig like below, then use a file to square up the end. I file it down flush.
Once it is flush I clean up the ID. I have tried using the deburring tool on the cutter as well as using an exacto blade to clean it up and chamfer a bit.
I remove from jig and file the OD down so there is no burr and chamfer it just a touch, make sure die slides in nice and easy. See below.
Next, I put it in the jig again (with beveled side of jig up of course) and set the depth to the first notch on the die.
Then insert the die, put on the other half of the tool and crank the living piss out of it to get it as tight as possible.
Then I slowly tighten the top to make the flare, only going until the die touches the bottom of the jig and not cranking it too tight. My issue is that the bubble doesn't form, I just end up with this
You can see that it is moving in the jig. I am cranking it down on the side one (that does the tension) as tight as I can get it though. The one for the picture I put the jig in the vise and then tightened it even more.
I notice that the 3/16" hole in the bottom part of the tool is the only one not ribbed.
I have also tried adding a little brake fluid to the contact points as lubrication, I read somewhere else that it would solve my problems...it didn't.
I did some of the brake lines a few years ago when I swapped to one tons and borrowed a badass Ridgid unit and it worked flawlessly. I am unsure why I am struggling so much this time around. The tool is brand new, as are the dies. All brand spanking new.
Any suggestions or tips for me? Is there anything I am not seeing here?
Thanks in advance
Thanks in advance
