rock hard
dnf
I picked one up a while back for modding pinions.I may have 100 hrs on it max.The variable speed switch took a dump.
I work at low rpm most of the time,and when it went out all I had was wide open.So I opened it up,took air to the switch and she is back in buisness.
You dont have to remove the brushes,but be aware the lock down for the shaft is a bit tricky to get back in properly,there is a loose pin inside the button,I super glued it place (inside the button),and it was easy after that.
But if you have one that acted simulare,its a easy fix,just needs a cleaning is all.
