MR.VERTICAL
Alot of people have ask me about this mod so i thought i would do a quick how to hope this help.
Frist take a wide hex and a vp hub bolt it to a 1.9 rim.
Then take a 5/32 drill bet using the hub as your guide, after that take the hub off then redrill the holes using a 1/8 drill bet.
Then using a 13/32 drill to open up the center hole to fet your wheel wrench.
Then you have two ways you can bolt up ether put the bolt throw the rims then add nut for that stock look or bolt them up as normal i hope this help,
