Driveshaft, you are the WEAKEST LINK
jfalesi
USA
First run with a 3S, my friend's kid tore up the driveshaft on my Yeti Score TT. I assume this was only a matter of time... I know there are upgrades from MIP and SSD - what are the pros/cons? Will non-TT Axial driveshafts fit the TT?
its just the wild boar style driveshafts that axial utilizes across their vehicle line. The TT and rock racer versions both utilize the same driveshafts I believe. What exactly got thrashed?
Yeah, I think you're right. The center spline twisted a little bit and the rear end where it mates with the squared off driveshaft coupler was completely torn up. I think it was because we were running it on asphalt on a hot day (it was like 97 or so), and my kid's friend probably did a full-reverse-to-full-forward move. With all that traction, the plastic basically shredded. I'm going to get a new WB8-HD driveshaft set, but I saw that the SSD and MIP upgrades are both available from RPP Hobby.
Does anyone have a preference between the two?
No issues with the stock wb8 drivesaftes so far. And im running only 3s high power systems in my little monster.
Only lost 2 middle splines as my rod ends broke on the ssd trailing arms in some hugh tumbles. But i will stay with them cause it's my weak spot in the rear easy and cheeps to repair.
In some thread are complains about the MIPS.
Love my ssd parts so i would go ssd If i ever decide to change the shafts.
Send by my Pixel 2 XL with Tapatalk
Nice. I bought a replacement WB8 but if it happens again I'm going with metal driveshaft and links. I think I'll be OK as long as I don't let my friends' kids bash around on 3S :-D
You brake your driveshaft means most of the time that your slipper isn’t working.
The slipper slips for a reason. Yeti/score/YetiXL slippers are crap...hard to adjust, not consistent, and jam way too easy.
Robinson racing 1564 or 1556 is a good replacement
Thanks. If I keep having problems I'll look into one of those.
Well, two runs on 3S and two shredded driveshafts. This time it left a screw behind...
So... just out of curiosity, what else should I expect to fail? In other words, why should I have bought the kit rather than the RTR? lol
It doesn't look broke just as you lost the lower spline, which is hold by a screw. did you locktide the screw as you assembled it?
otherwise i would assume you just had a loose screw.
The MIP shaft is nearly indestructible. You'll get to find out what will break next.
Sent from my ONEPLUS A5010 using Tapatalk
No, I didn't loctite them. Wouldn't be the first time I've been accused of having a screw loose!
Here's the link from the transmission side. I couldn't find the other link or screw - my guess is the other screw came loose and the link flew off somewhere, then this link pulled itself off the screw head.
