I bought some hot racing shocks. Instead of oil I used some wheel bearing grease (already had it and it's marine grade lithium grease). I'm fine with that part, though I'm welcome to concerns and ideas, I also swapped the softer black springs on before I installed them, but I get a fair amount of compression while it's just sitting on the work bench. I understand having droop on a full size rig is great, but I'm wondering how everybody else has their rig setup. Do you guys run with some compression or keep the springs tight enough to keep the shock at full extension?
