I run dual 3s 2200mah mounted on top of my sliders
using a parallel wiring harness and the orig. esc.
But I have to use a external BEC (battery eliminator circuit)
with the orig. castle esc that came with my Honcho.
Other Axial rigs come with a newly designed Tactic system
and is no longer compatible with the castle products.
But it is switchable and can run 3s LiPo straight out the box (rtr).
2s wired parallel is still only 7.4 volts...
the parallel harness simply combines the mah
for extended run times.
You could just use a single 2s battery of higher mah rating
and mount that laterally across the frame
just in front of the transmission.
Running duals works for me...
But they must balance/ballast each other out
in order to be worthy of doing. jmo
Duals can also add more weight
if selecting the wrong battery size.
My 3s 2200 mah combined is 4400mah
so a single 4000 - 5000 mah 2s LiPo
could be more cost effective and weight reducing for some.
I personally like the added weight.
But that weight needs be mounted as low as possible.
And that's why mine are mounted atop the sliders.
Because I utilize a full Dinky interior in my honcho...
battery placement and room to do that is a critical thing.
Here's some pictures of my duals mounted atop the stock sliders.
realize that a 2s LiPo is smaller then 3s
so it should be easier ;-)
