e-flite brushless
Rick Tomsett
out there
has any one tride a e-flite 25 out runner yet? they say it has more power than a .21 nitro engine. with a mamba 25 it could work yes or no?
its too big for mounting to a gearbox and it draws way more than 25 amps if i remember right a .21 car motor puts out way more power than a plane engine does too
Specs
Type: Brushless Outrunner
Size: Replacement for 25-size glow engine
Bearings or Bushings: Ball Bearings
Wire Gauge: 14
Recommended Prop Range: 11x8 to 14x7
Voltage: 12 - 16.8
RPM/Volt (Kv): 870
Resistance (Ri): .03 ohms
Idle Current (Io): 2.40A @ 10V
Continuous Current: 32A
Maximum Burst Current: 44A (30 sec)
Cells: 3S-4S Li-Po or 10-14 Ni-MH/Ni-Cd
Speed Control: 40A - 45A Brushless
Weight: 190g (6.7 oz)
Overall Diameter: 35mm (1.4 in)
Shaft Diameter: 5mm (.20 in)
Overall Length: 54mm (2.1 in)
I think those will mount up to a gearbox just fine (been a while since I held one), but the mamba 25 would not quite handle it. 5mm shaft will be the only hurdle.
