crawlinghulls
We're hopeing to add some events on the Western side of CT this year hopefully everyone can make them. Feel free to check out the site www.ecrccrawlers.com
These rules will be used at all ECRCC Scale Events. If you participate in the point series please read carefully. WE have written these rules to encourage a diverse group of rigs and driving styles..Enjoy.
ECRCC Scale Rules - Rig Guidelines/Specifications
Four Wheel Steer and Dig not allowed. If you rig has either you will need to remove it or "lock it out" to the judges satisfaction.
1.0 BODY
Body must be used. Body to be 1/12th scale or greater and retain 90% of its original form (judges decision is final). Drivers may provide photos of the 1:1 rig that is being replicated.
In the event of a metal or plastic tubed back half - 90% of the Cab must remain (so you could remove the doors and that would be it) and the tubed bed area must be big enough to lay a full size spare flat (same size as the rig runs).
In the event of a flatbed the flatbed must extend over some part of the tires (width). The bed area must be large enough to hold a full size spare tire flat (same size as the rig runs). Scale Appearance Bonus points may be awarded to bodies/tubing/flatbeds depending on build material. See SAB points for clarification
1.1 BUMPERS
Bumpers must be represented. Please see Section 1.2 WHEELBASE for further clarification.
1.2 WHEELBASE
Wheelbase is determined by the body’s fender wells. Tires must be centered within fender wells, +/- 1/4 inch.
In the event of a tubed backhalf or flatbed the center line of the axle may not prodrute beyond the end of the tubing or flatbed. See Section 1.3 TIRES for further clarification.
1.2.1 WHEELBASE CLASSES
Bonus points will be awarded to short wheelbase rigs. Rigs will fall into one of the following categories see Scale Appearance and Bonus points for further clarification.
9 3/4 and under inches
over 9 3/4 - 10 1/2 inches
over 10 1/2 to 11 1/8 inches
greater than 11 1/8 inches
1.3 TIRES
Tires may not extend beyond the front and rear bumpers. Tires must also be partially covered by fenders. In the event of a tubed backhalf or flatbed the front fenders must cover some portion fo the front tires. If the trailing edge of the rear tire extends beyond the flatbed or tubing a bumper must be extended from frame. Only Approved tires may run. Cut/Modified tires allowed.
1.4 TIRE DIMENSIONS
Maximum inner diameter = 2.2 inches
Maximum tire height = 4.75 inches
*Tire height will be measured with the rig supporting its own weight on all four tires. Measurement will be performed on a flat surface with a standard measuing device that will measure height from ground surface to uppermost surface of the tire (all tires must pass this requirement)
1.5 APPROVED TIRES
All manufacturers 1.9 or 1.55 tires, approved 2.2 Cut/Modified tires allowed
The following tires are also approved (some may need to be cut to fit the height rule: HPI: Geolanders RC4WD: Crazy Krawler, Gauntlet, Mudslingers, Outcroppers, Rock & Die, Rock Crushers, Rock Stompers, Rock Lox, Spooky Krawler. Junfac: Bighorns. Imex: Swamp Dawgs, All-T's, Rubicons, G-Hawgs. Integy: ECR2, ECR3, ECR4, ECR5. Axial: Rock Lizards. Proline: Moabs, Badlands, Hammers, Mashers, Masher 2000, FlatIrons
1.6 CHASSIS
Chassis must consist of two frame rails (comprised of a right and left side). Frame must extend to the centerline of both front and rear axles
1.5 MOTOR/TRANSMISSION
Vehicle is powered by a electric motor(s) directly or indirectly powering a central transmission or transfer case which sends power to both axles.
1.6 BATTERY
Must be mounted on/in chassis. Battery may not be placed on axle.
1.8 WINCHING
Is allowed with no penalty other than elapsed time needed for use.
2.0 SCALE APPEARANCE AND BONUS POINTS - For SAB points to be awarded all items must remain on vehicle throughout the comp - Drivers may take a repair penalty on course to repair/replace scale item to retain points. Scale items may not be replaced between runs/courses
2.1 WHEELBASE:
9 3/4 and under inches (-5)
over 9 3/4 - 10 1/2 inches (-3)
over 10 1/2 to 11 1/8 inches (-1)
greater than 11 1/8 inches (no bonus)
2.2 Functional Scale Bonus Points (no max)
-Full hard body (-5)
-1/2 hard body, 1/2 tube work (metal) or flatbed (aluminum or hardwood/flooring) (See Scale Build Rules) (-5)
-20% lexan rule - in order to receive -5 bonus no more than 20% of body can be lexan. Lexan cab with hard body bed would not qualify and recieve a -3 bonus. Hard body with lexan fender flares, lexan visor, and lexan tailgate would recieve -5 FSB points. TECH DIRECTOR WILL MAKE FINAL DECISION
-Metal leaf spring suspension (-3 front or rear, -5 front and rear)
-Delrin leaf spring suspension (-2 front or rear, -3 both)
-Frame mounted steering servo (-5)
-Full width trailer (must be towed during comp) (-6)
-Tires less than 4 inches tall (-5) ****
-Tires with height 4 - 4 1/4 inches (-3)****
-Faux motor which covers/conceals an electric motor in a real world factory location (-5)
-Functional full size* spare tire (must be carried on the roof or rear bumper of the rig. Weight must be equal to one front wheel/tire ) (-5)
-Nonfunctional full size spare tire, must be carried on the roof or rear bumper, must be made up of same tire/wheel combo as rig runs (-3)
-Aluminum/metal axles (one axle -3/two axles -5)
-Sound system (music or engine), must play during comp (-5), both would score (-10)
-Functional snow plow -6, remote operated (-8)
-Metal bumpers must be frame mounted (bolted or weld)(-3 front, -2 rear)
-Frame mounted plastic bumpers (-2 front, -1 rear)
-Remote operated opening door (-3 for one, -6 for two independent doors controlled from transmitter)**
-Remote operated windows (-3 for one, -6 for two independent windows controlled from transmitter)***
-Electric wipers (-3 for one, -6 for two independent wipers - controled from transmitter)
-Metal sliders (-5)
-Plastic sliders (-3)
-Metal roll bar or metal headache rack-5, plastic (-3)
-Functional winch (-3 front, -3 rear, -6 both)
-Metal roof rack (-5 )
-Functional head and tail lights (2 front/2 rear - must function during comp) (-5)
-Accessory lights (lights in addition to 2 front headlights/2 rear taillights) (-1 each/6 max)
-Functional window (-1 user pushes the window down with finger or thumb) (if two -2)
-Functional door (-1 user opens door with finger or thumb) (if two functional doors -2)
-Tow rope (functional -2)
2.3 Scale Appearance Bonus Points (20 POINTS MAX)
-Non functional headlights/taillights (2 each) (-2 must be lenses - not stickers)
-Nonfunctional accessory lights (-1/pair, -3 max )
-Driver figure (must be scale to rig) (-3 each, no max, seating must be available for every figure)
-Interior - Styrene/Hard plastic - two seats, steering wheel, full dash, and one of the following - shift lever, interior door handles, floor pedals (-5)
-Interior -lexan must meet the same scale appearance guidlines as the interior listed above (-3)
-Large accessory (canoe, kayak, mountain bike, etc..) (-4)
-Large bed accessory (motorcycle, quad, lawnmower, gas grill with tank, engine, dishwasher, king size bed etc..) (-2)
-Faux motor (-2)
-Scale lockable hubs (-1 for 2, -2 for all 4)
-Disc brake hexes (-1 for all four)
-Plastic rollbar or headache rack (-2)
-Nonfunctional winch (-1/front or rear, -2 both)
-Jack (-2)
-Propane tank (-1each, max -2)
-Jerry can (2 max) (-1 each)
-Bungees (at least two for bonus -1, 6 Bungees for max of -3)
-Tow rope (nonfunctional) (-1)
-Axe, shovel, rake, wrench, beer can, GPS, etc (-1, -5 max)
-Exterior mirrors (-1 drivers or passenger, -2 for both)
-Scale windshield wipers, not stickers (-2 for both)
-Nonfunctional spare tire - may be a different wheel/tire than what's on the rig (-2)
-Fire extinguisher (-1 each, 2 max)
-Potted plants (-1 each, max -2)
-Trees (-1 each, max -3)
-Cord of wood (solid wood, not hollow) full size bed full of cut wood (-5)
-Full size extension ladder (-2 each, max two)
-Sleeping bag (-1 each, max 2)
*full size spare must be comprised of tire and wheel matching those run on the rig. If a driver changes tires between comps and does not change the spare as well, it will no longer qualify as a full size spare. ie axial beadlocks w/flatirons get a spare made of a axial beadlock and flatiron (not an axial beadlock with a rock crusher)
** window may be a manual crank type but this must be functional/demonstrated before and after the comp
***door may be a manual lever mechanism - mechanism must be operable from the exterior of the door, must be functional/demonstrated before and after the comp
****Tire height will be measured with the rig supporting its own weight on all four tires. Measurement will be performed on a flat surface with a standard measuing device that will measure height from gorund surface to uppermost surface of the tire (all tires must pass this requirement)
3.0 HOW WILL THE SAB POINTS AFFECT FINISHING ORDER AT COMPETITIONS
Course 1 Score - determines run order for course 2, awards +2 pts series bonus for low score+
Course 2 Score - determines run order for course 3 (if applicable), awards +2 pts series bonus for low score +
SAB points = finishing order
*low course score would be based on penalty points only.
1.0 BODY
1.1 BUMPERS
1.2 WHEELBASE
1.3 TIRES
1.4 TIRE DIMENSIONS
1.5 APPROVED TIRES
1.6 CHASSIS
1.6 BATTERY
1.8 WINCHING
2.1 WHEELBASE:
-Metal sliders (-5)
-Faux motor (-2)
-Jack (-2)
