SeanD
Some part of the electronics on my WK cr#pped out this weekend and I am trying to determine which it is. Its all stock. Here's the gist:
Thursdsay night - motor stopped working properly. It would stick and humm. I am thinking that it was held in a stall (not by me) with low batteries and that perhaps this burned the winding. I thought maybe a run in a cup of water would work (I have a new 55t coming in so I thought "what the heck".) The motor ran great - better than ever before - after that but it appears too great. It must have pulling more amps than nomal
Sunday Morning (Happy Father's Day!!!) my son took the WK for a drive around the living room and then informed me that it was not working right - it was jerking backwards. I felt the ESC and it was very hot (I normally run a separate fan on the ESC when crawling but as this was just driving around the house it was not turned on) I manged to get the motor running again but it was arcing REALLY bad and smoking. So naturally I stopped.
Here's what the thing does now:
turn on ESC and transmitter and the steering servo jerks and the motor cuts in out at full throttle.
turn off the transmitter and the motor beeps - like normal.
Voltage off the ESC to the motors jumps all over the place - even without the throttle pressed.
The steering servo will respond to the transmitter but slowly and with no power and only in between jerks described above.
I hooked up a similar motor and it behaved the same way.
Should the steering servo respond to the transmitter with the ESC leads to the motor disconnected. I can only get the servo to move when the motor is hooked up. Is this normal?
I am really at a loss here so any suggestions would greatly. Would this be an ESC or transmitter problem - or both!
I don't mind buying a new ESC as breakage is always a good excuse for an upgrade but I like to know that I'm replacing something that HAS to be replaced at this time. Its unlikely that my LHS will have a ESC so I'll be looking at a two week downtime. Of course, my 55t motor and 96t and 15t gears should be here later this week so I'll have to just look at them and not get a a chance to try them!!!
Sean
(yes I posted this in the Electronics Forum but I think those of you with WKs may have some better insight)
Sean
