FlySky Fs-g7p transmitter glitch
setecastronomy
Italy
Some months ago I bought a Flysky fs-g7p radio but I did't use it very much. Lately I noticed a bad glitch on Ch1, cannot say if it was there from the beginning.
In an effort to solve it I upgraded the firmware to the latest one. As a consequence of the upgrade the configuration is restored to default, so I can now exclude the glitch is due to a wrong configuration. I tried a different receiver and servo and the problem is still there, but I have another proof that there is something wrong in the transmitter: watching carefully the transmitter display I can see the glitch on the signal level.
Here is how it behaves:
- chattering returning to neutral on ch1 for few seconds, then it is steady for tens of seconds before a new chattering starts
- sometimes steering full left the signal level oscillates for 2-3 times from full left to 3/4 left
- sometimes steering full left or right Ch2 moves a bit forward or backward as there was an active 5% mixer
Do you think I have a defective hardware ? Did anybody have similar problem ? Any suggestion before changing radio ?
Thanks
Filippo
Ferp sounds like he’s on the case. Without his help I would say chuck it up to the radio and ask for a new one. If his help doesn’t work maybe time to call the manufacturer.
Good luck to you and have a good day.
The receiver is FS-R7P, and I believe it has no gyro. Besides I can clearly see the glitch in the signal level shown on the transmitter display even when the receiver is turned off.
I re-checked the configuration, all mixers are off and abs is off. There is also a parameter like 'channel speed', which should act as a low pass filter, but it is disabled.
