? for txt owners
venomous98
Antioch
Could some one please tell me what size wheel hexes are on the stock TXT, also what size are the out put shafts on the axles ( where the drive shafts go) ?
a stock TXT wheel adapter is like the clod... black hub that bolts to the wheel. There are adapters ( splined inside), and let you run a 12, 14, 17mm hex...
as for pinion shaft size... you will need 6mm drive shafts. But if you want to run a 5mm transmission, the older MAXX's have 5mm yokes, using those, you can go from 5mm to 6mm without making or buying an adapter.
the hex sized is 12mm, they make a 12mm to 23mm conversion so that you can run different rims, they also make an adapter for the TMAXX rims.
dont know about the shafts.
