photon_trap
This is driving me nuts. I just installed a set of VP knuckles and C blocks and as I am attempting to re-set my steering servo end points end points I find I have an extreme case of what seems to be some sort of driveline binding anywhere near full lock. As I run it up, (on work stand) everything is fine when going straight, but when you get to a certain point turning L or R, I get a severe "irregularity" (for lack of a better term). What was smooth rotation turns into a almost crunching mess.
I have seen something similar with worn bearings in the front but all his stuff is new or in very good shape.
With the the wheels off it is barley noticeable, but with wheels on (even loose) it appears... Also, it does he same thing, regardless of where the suspension is in it's travel.... At first I thought I was exceeding the limits of the CVD in terms of angle but it starts at what seems to be about 2/3 of its range.
I did have the Diff apart (100K cst) but it seems fine doing what you would expect a diff to do.
Any insight is appreciated, staring at it and thinking does not seem to be helping - Ha!
