Front knuckle bearing size?
tyerfryersc
Howell
Does anyone know the size of the front knuckle bearings on the stub shaft side? I had an outer bearing fail. On a Scx24 w HR brass knuckles.
Not off-hand, here's the manual which doesn't state the sizes.
http://docs.axialracing.com/instructions/kits/AXI90081_-_SCX24_Deadbolt_RTR.pdf
I got my ECX Barrage bearing kit from Fast Eddy, but no listing yet for the Axial SCX24
https://www.fasteddybearings.com/
Didn't find bearings on Horizon or Axial sites, measure the bearings and order from Avid, I've bought from them before.
https://www.avidrc.com/
I believe all the bearings in the scx24 are the same size.
When I swapped my axel out for the HR aluminum one I broke a bearing trying to pop it out of the plastic housing. I emailed support and the replied with this.
Thank you for contacting our product support team. The bearing size is 3x6x2.5mm.
Hope this helps
