The SCX24 worm gear axle is already geared down significantly compared to a ring and pinion axle so that definitely helps. I wouldn't expect the same performance with an 8kv motor on a ring and pinion axle.
I also wouldn't exactly say this ESC is changing conventional thought about ESCs, a higher KV motor will still draw more current, make more heat, and not perform as ideally as a similar motor with lower KV and more voltage geared down.
John Holmes has far more crawler specific knowledge than most and even with his ESCs his mantra is volt up,gear down.
As far as the Furitek most of the videos I've seen are best case scenario with a HUGE outrunner showing off slow speed on a flat surface with no load on the motor, which IMO doesn't tell you anything because even a low/mid grade ESC can do that. The one or two videos I've seen with stock or aftermarket brushed motors seem to perform about the same as other ESCs in this price range like castle, holmes and Tekin.
IMO this ESC will still be the most popular option because of all the new people into micros and RC.
This is plug and play so no soldering needed for the SCX24, it's compact for the features it offers,seems to perform as well as the top ESCs, has the ability to be fine tuned like higher end ESCs, and has some LED support.
My biggest concern with Furitek Is quality control, I've heard of them before with the other ESCs but have never known of anyone running them, now that the new ones are out in the wild I'm already seeing a surprising amount of failures leading to burned up ESCs and motors, and I believe one person claiming it caught on fire.
I'll personally be waiting for a few more batches to see how things go with others. Once they seem reliable I'll for sure pick one up to compare to my Castle,Holmes, & Tekin, as is with what it offers the performance doesn't even have to be quite to the level of the "big 3" for it to be a good value (so long as they don't keep burning up)
Sent from my Pixel 3 XL using Tapatalk
