futaba 4pl problem
waynedizzle
BONITA SPRINGS
i just got a 4pl hooked up to my wraith n the brakes are weak n in reaverse it flashes blue n like glicthes bad bad still goes..any ideas or a program setup...
You are going to have to provide more info for us to help you out. What ESC, batteries, motor, do you have a BEC. The more info we have the better we can understand the problem ;-).
The brakes being weak sound like a ESC/motor problem to me...
When you look at the receiver does the green light come on and glow solid green? Does it show red at all? If it is on and green, it should be good to go, no glitching.
If you have a power hungry servo with no BEC, that could be causing browning out of the receiver and signal loss.
i git the traxxas vxl system no bec...works fine in forward lite blue..in reverse it flashes blue n the motor goes with the flash...i got a hitec 7955 tg..it worked fine with the wraith radio but the 4pl when i put it in it would just rev byitself...i mess with the hundred settin in i got it as good as i can..just now weak break n glitches in reverse
